Master Work Order Headers for Style Items
You use the Master Work Order Processing for Style Items program (PCW49) to enter a work order header for the master work order.
For a master work order header, you enter the description, order type, branch/plant, and requested date for the master work order. You can also enter other optional information, such as the revision level for the bill of material and category codes.
Note: You need not enter style item numbers in the header for the master work order.
The system stores the master work order header information in the Work Order Header for Style Items table (FCW65).
