Revising Parts Lists for Master Work Orders for Style Items
Access the Master Work Order Parts List Details for Style Items form.
To revise parts lists for master work orders for style items:
To delete all components on the parts list, select Delete Parts List on the Form menu.
To delete one component on the parts list, select a line, click Delete, and then click OK.
The component is removed from the parts lists of all child work orders.
To modify the quantity of one component, enter a value in the Quantity Ordered field.
The quantity of the component is changed only for that particular work order where this components is used and not in all parts list of child work orders where it exists. The quantity follows the same ratio between the quantity before and after the change.
To add a new component:
Enter the item number and quantity.
Enter the line number of the component from which you want to inherit information and split in the Line No (line number) field.
The quantity ordered of the new component is split among individual child work orders based on the same ratio as the original component that you are pointing to.
Click OK.
