Understanding Style Item Master Conversion
The JD Edwards EnterpriseOne Inventory Management and JD Edwards EnterpriseOne Apparel Management systems store style items in the Item Structure Definition (FCW02) and Item Master (F4101) tables. The system stores additional style item information in the Additional Style Item Information table (FCW61) and standard JD Edwards EnterpriseOne items in the F4101 table. You can convert a standard JD Edwards EnterpriseOne item to a style item using the Style Item Master Conversion program (RCW04). When you run the Style Item Master Conversion program, the system copies the standard item details to the FCW02 and FCW61 tables. You can access the converted item details through the Style Item Master program (PCW51).
