Setting Up Inventory Management for Requirements Planning
When you set up the item master and branch/plant information, you provide JD Edwards EnterpriseOne Requirements Planning with the information that it needs to create accurate master schedules, material requirements plans, and distribution requirements plans. JD Edwards EnterpriseOne Requirements Planning uses the values in these fields:
Stocking Type
Planner Number
Buyer Number
Supplier
Lot Process Type
Master Planning Family
Category Code
Unit of Measure
Order Policy Code
Value Order Policy
Planning Code
Planning Fence Rule
Planning Fence
Freeze Fence
Message Display Fence
Time Basis
Shrink Factor
Leadtimes
Quantities
When the items are defined in the Item Master program (P4101), you can further define the items at the branch/plant level using the Item Branch program.
Use the Item Branch program to specify information for each item. This information is critical to JD Edwards EnterpriseOne Requirements Planning:
