Setting Up Enterprise Automation for Order to Cash Process Page in EnterpriseOne
To view the Enterprise Automation for Order to Cash Process page:
Select Enterprise Automation (G42EA), Sales Process.
Alternatively, click the Menu at the top left of your EnterpriseOne page and enter EA_Order to Cash in the Search field, then select EA_Order to Cash from the search result. Or, you can click the login user name drop-down menu, select My Content under the Personalization category, and then My Pages. Select the EA_Order to Cash check box and click Save.
The Enterprise Automation for Order to Cash Process page is displayed on your Home page on the EnterpriseOne Page.
When selected, you can see that the page displays a set of tiles and watchlists. The flow of the process is also indicated by arrows.
You must have the required UDO security access to view EnterpriseOne pages. For more information on UDO security, see "Understanding Security for User Defined Objects".
