Using Enterprise Automation for Procure to Pay Process Integrated with Warehouse Putaway (Release 9.2 Update)
The Procure to Pay process is now integrated with Warehouse Management. Through the Warehouse Putaway tile, you can access Warehouse Management from existing Procure to Pay processes.
You can view the detailed Warehouse process by clicking this tile. A typical end-to-end process flow of warehouse management (EA_ Warehouse Putaway) process is modeled as EnterpriseOne Pages. The end-to-end process flow enables you to drill down to detailed process flows of specific process steps like request creation, suggestion, confirmation, cancellation, and closure. Tiles are used to represent steps in the process. The Watchlists on the tile provide a quick insight to warehouse supervisor or manager on critical updates and important metrics related to the process step associated to the tile.
