Receipt Routing Process Model Template Metrics
The Process Analytics tab displays details such as Filter Criteria, Return Fields, Context Analytic, and so on for the related tables and business views of the selected enterprise process template. The Process Analytics is used to analyze and measure the overall performance of the process.
Metrics Object Type Object Name and Description Series Type Chart Name and Description
Process Analytics
Movement Code
Table - Analytic
F43099 - Receipt Routing Ledger File Based on Returns
Movement Category
Use this chart to view the count of movements categorized by code or category.
The chart depicts the count by category vertically.
Reason Code
Table - Analytic
Disposition - Reason Codes
Use this chart to view the count of dispositions categorized by disposition reason.
The chart depicts the disposition count vertically.
Nodes Metrics and Analytics
Total Count
Table -Metrics
Receipts by BP
This chart shows the total count of receipts in the node. The count is categorized by Branch Plant and is displayed vertically.
Link Metrics and Analytics
Total Count
Table -Metrics
Receipts by BP
This chart shows the total count of receipts at a selected link. The count is categorized by Branch Plant and is displayed vertically.
