Running the Voucher Match Automation Process
Select one of these options from the Voucher Automation Processing (G43B15) menu:
Voucher Match Automation - Non logged voucher
The system runs version XJDE0001 when you select this option.
Voucher Match Automation - Logged voucher
The system runs version XJDE0002 when you select this option.
Note: When you run any version of the Automation
Match Voucher process, the system runs versions of the Voucher Match Automation UBE
programs (R4304016, R4304020, and R4304021). When you run the XJDE0002 version of
the Automation Match Voucher process, the system also runs the Batch Voucher
Processor Report (R04110ZA).
