Completing Equation Engine Setup
You must set up Equation Engine before using it. This section discusses how to:
  • Recompile all equations prior to using Equation Engine.
  • Verify equation security objects.
  • Adjust equation security.
  • Create a tree hierarchy.
  • Set up security authorizations.
Pages Used to Set Up Equation Engine
Page Name Definition Name Navigation Usage
Run An Equation
SCC_EQTN_RUN_CNTL
Set Up SACR, and then Common Definitions, and then Equation Engine, and then Run Equation, and then Run An Equation
Compile all equations prior to using Equation Engine.
User Profile Types
PSOPRALIASTYPE
PeopleTools, and then Security, and then Security Objects, and then User Profile Types, and then User Profile Types
Tree Definitions and Properties
PSTREEDEFN
Tree Manager, and then Tree Manager
Click the Tree Definition link on the Tree Manager page.
Adjusting equation security.
Tree Manager
PSTREEMGR
Tree Manager, Tree Manager
User Profiles
PSOPRALIAS
PeopleTools, and then Security, and then User Profiles, and then User Profiles
Compiling All Equations Prior To Using Equation Engine
Access the Run An Equation page (Set Up SACR, and then Common Definitions, and then Equation Engine, and then Run Equation, and then Run an Equation).
This example illustrates the fields and controls on the Run An Equation page. You can find definitions for the fields and controls later on this page.
Anyone using Equation Engine in your organization must complete the steps in this section to recompile equations.
To recompile equations:
  1. Enter the equation EQCOMPILEALL.
  2. Leave the Global and Type fields blank.
  3. Click the Run button.
  4. Click the OK button on the Process Scheduler Request page.
  5. Verify that the job ran successfully by checking the Process Monitor.
Verifying Equation Security Objects
Access the User Profile Types page for EQD (PeopleTools, and then Security, and then Security Objects, and then User Profile Types, and then User Profile Types).
Financial Aid and Student Financials administrators must complete the steps in this section to verify equation security objects.
This example illustrates the fields and controls on the User Profile Types page (EQD). You can find definitions for the fields and controls later on this page.
Verify that the information that appears matches the information provided in the preceding page.
Search the following ID types:
  • EQN
  • EQS
  • EQX
Access the User Profile Types page for EQN (PeopleTools, and then Security, and then Security Objects, and then User Profile Types, and then User Profile Types).
This example illustrates the fields and controls on the User Profile Types page (EQN). You can find definitions for the fields and controls later on this page.
Access the User Profile Types page for EQS (PeopleTools, and then Security, and then Security Objects, and then User Profile Types, and then User Profile Types).
This example illustrates the fields and controls on the User Profile Types page (EQS). You can find definitions for the fields and controls later on this page.
Access the User Profile Types page for EQX (PeopleTools, and then Security, and then Security Objects, and then User Profile Types, and then User Profile Types).
This example illustrates the fields and controls on the User Profile Types page (EQX). You can find definitions for the fields and controls later on this page.
Do not use the EQA ID type at this time.
Adjusting Equation Security
Access the Tree Definitions and Properties page for EQTN_IDAUTH_TREE (Tree Manager, and then Tree Manager and click theTree Definition link on the Tree Manager page).
Financial Aid and Student Financials administrators must complete the steps in this section to adjust equation security.
This example illustrates the fields and controls on the Tree Definitions and Properties page (EQTN_IDAUTH_TREE). You can find definitions for the fields and controls later on this page.
Search for the following tree names:
  • EQTN_SQAUTH_TREE
  • EQTN_TBAUTH_TREE
  • EQTN_XAUTH_TREE
If you need to create any of these trees, also use the following page elements :
Field or Control Description
SetID
(blank)
Set control value
(blank)
Tree branch
(blank)
Valid tree
Valid tree.
Tree root node
PUBLIC
Access the Tree Definitions and Properties page for EQTN_SQAUTH_TREE (Tree Manager, and then Tree Manager and click the Tree Definition link on the Tree Manager page).
This example illustrates the fields and controls on the Tree Definitions and Properties page (EQTN_SQAUTH_TREE). You can find definitions for the fields and controls later on this page.
Access the Tree Definitions and Properties page for EQTN_TBAUTH_TREE (Tree Manager, and then Tree Manager and click the Tree Definition link on the Tree Manager page).
This example illustrates the fields and controls on the Tree Definitions and Properties page (EQTN_TBAUTH_TREE). You can find definitions for the fields and controls later on this page.
Access the Tree Definitions and Properties page for EQTN_XTAUTH_TREE (Tree Manager, and then Tree Manager and click the Tree Definition link on the Tree Manager page).
This example illustrates the fields and controls on the Tree Definitions and Properties page (EQTN_XTAUTH_TREE). You can find definitions for the fields and controls later on this page.
Creating a Tree Hierarchy
Access the Tree Manager page (Tree Manager, and then Tree Manager).
This example illustrates the fields and controls on the Tree Manager page. You can find definitions for the fields and controls later on this page.
Tree Manager page
Create a tree hierarchy from the PUBLIC node if one does not already exist for each of the trees. The tree hierarchy should contain a separate node for Financial Aid administrators and a separate node for Student Financials administrators. You can break this down further if you want to limit who can run equations versus who can edit an equation within the groups.
Tree Name Description
EQTN_IDAUTH_TREE
Authorizations for editing, viewing, or running equations.
EQTN_SQAUTH_TREE
Authorizations for editing or running equation SQL.
EQTN_TBAUTH_TREE
Authorizations for reading tables and view from an equation.
EQTN_XTAUTH_TREE
Authorizations for running external COBOL routines from an equation.
Do not use EQTN_AEAUTH_TREE at this time.
Access the Edit Data page (click the Edit Data icon on the Tree Manager page).
This example illustrates the fields and controls on the Edit Data page. You can find definitions for the fields and controls later on this page.
Edit Data page
Under each node, add or edit the list of objects and indicate what level of security should be applied to the node.
To do this, click the Edit Data icon (pencil icon) and then insert rows of equation object names and grant appropriate authorization levels.
Execute
Select the Execute value if the user has the security clearance only to run equations.
Read
Select the Read value if the user has the security clearance to read and run equations.
Write
Select the Write value if the user has the security to write, read, and run equations.
All tables and views should have only Read access at this time. Equations should have a mix of authorizations depending on the position of the person accessing them. External routines and SQL should have only Execute access.
You should create the node hierarchy and save the tree structure before adding equation object names so that authority propagation can take place.
Objects newly placed within the PUBLIC node should have their access propagated to Append Auth to All Child Nodes.
Save any changes you made to the trees.
Setting Up Security Authorizations
Access the User Profiles page (PeopleTools, and then Security, and then User Profiles, and then User Profiles).
This example illustrates the fields and controls on the User Profiles page: ID tab. You can find definitions for the fields and controls later on this page.
For each person in a department who needs security authorization other than PUBLIC, you must follow these steps:
  1. Enter the person's ID number and access the ID tab.
  2. Enter each of the four EQ ID types in the ID Type and Values fields.
  3. Enter the appropriate Equation Security Tree node name for each of these ID types.
  4. Save the user profile.
See PeopleTools: Security Administration
