Enabling Classic Plus for Campus Solutions Components
Use the Classic Plus Setup page to enable or disable the Classic Plus user interface for CS Classic components.
From this page, you can also view a list of the application components that are delivered as Classic Plus.
Page Used to Set Up Classic Plus
| Page Name | Definition Name | Navigation | Usage |
Classic Plus Setup |
EOCP_SETUP |
Enable or disable the Classic Plus user interface for Classic components. You can also view a list of the application components that are delivered as Classic Plus. |
System Branding for Classic Plus
| Field or Control | Description |
Current Setting |
Displays the current Classic Plus configuration status at the system level (as given in the PeopleTools - Branding System Options page). If System Classic Plus branding is enabled, then the current setting is displayed as Enabled. Otherwise, it displays Disabled. |
Disable Classic Plus / Enable Classic Plus |
Select to disable or enable Classic Plus for classic components at the system level. This field is displayed based on the current system settings. For example, if the Classic Plus feature is enabled at system level, the field appears as ‘Disable Classic Plus'. |
Component Search Filters
Use this section to narrow your search results that appear in the Component Classic Plus Branding section.
Delivered Setting |
Select to filter the component list according to the delivered setting. |
Component Name |
Select the component to display in the component list. |
Current Setting |
Select to filter the component list according to its current setting. |
Owner |
Select the PeopleSoft application owner to filter the component list. For example: Academic Advisement, Recruiting and Admissions, and so on. |
Minimum Recommended Resolution |
Select a resolution to filter the component list. |
WorkCenter Homepage |
If you select Yes, the component list displays components that have a WorkCenter landing page. |
Action |
Select to filter the component list according to the action you've selected: Enable or Disable. |
Enable All or Disable All |
Clicking either button selects all the components listed in the Component Classic Plus Branding section and sets the Action column to either Enable or Disable. To complete the action, click Run. Depending on the action you took, the Classic Plus UI is either enabled or disabled for all components. |
Description |
Click the link to open a new tab or window to access the component. |
Select one of these options:
Delivered Setting |
This value indicates whether Classic Plus is delivered as enabled or disabled. |
When adding a new component, select a value from the available options. The value defaults to Not Applicable, which applies to components when the Classic Plus style isn't recommended. |
Current Setting |
This value indicates whether Classic Plus is currently enabled or disabled for the component. |
Action |
You can change the Current Setting value for a specific component by changing the value in the Action field for that specific row. Then, you need to click Run to apply the change. If you perform multiple searches and change the action for multiple components, be sure to click Save before you click Run. |
Click to add a new row to the grid. When you add a row, fields become available that you need to fill out. When a row is added, a delete row button appears to the right. Note: You can use this to enable Classic Plus for new or custom components. After adding the component, set the action to Enable then click Run to complete the setup. |
