Performing Data Conversion
This section provides overviews of the conversion process and referential integrity and discusses how to:
  • Map data for conversion.
  • Prepare data for conversion.
  • Verify converted data.
  • Use data dictionaries.
  • Use data load programs.
  • Keep systems in sync.
  • Estimate disk usage space.
If you implement Campus Solutions and a separate instance of PeopleSoft Human Capital Management, read the relevant documentation about CS-HCM Integration to understand the setup, functional, and technical implementation considerations. See:
Integrating Person Data
Integrating Setup Data
Monitoring Integrations Using the Integrity Utility
See Information Center: CS-HCM Integration for PeopleSoft Enterprise Campus Solutions in My Oracle Support (ID 2091799.2).
See PeopleTools: Data Management
