Using the Contributor Relations Homepage
This topic describes the delivered Contributor Relations Homepage.
Page Used to Access the Contributor Relations Homepage
Page Name Definition Name/Content Reference (CREF) Usage
CS_SAV_OUTREACH_HOMEPAGE_FL
Access a variety of Contributor Relations self-service transactions.
Use the Contributor Relations Homepage to access a variety of self-service transactions.
Navigation:
On a mobile device, the Fluid home appears when you first sign in. On a desktop or laptop, access the Fluid home by selecting Fluid Home under the main menu or the NavBar.
The default homepage title appears at the top of the homepage. If the Contributor Relations Homepage is not your default homepage, select the title of the default homepage and select Contributor Relations Homepage from the list that appears.
Tile on the Contributor Relations Homepage
Depending on the homepage setup, you may be able to choose which tiles appear on the homepage.
Tile Name Description
Donor Prospects
Select this tile to:
  • search Donor Prospects
  • view a Prospect Profile
  • manage Prospect Actions
  • manage Prospect Strategies
