Using the Faculty Homepage
The Faculty Homepage lets instructors access the fluid version of Faculty Center.
Pages Used to Access the Faculty Homepage
Page Name Definition Name/Content Reference (CREF) Usage
Faculty Homepage
CS_FACULTY_HOMEPAGE_FL
Access self-service transactions using the fluid user interface.
Faculty Homepage
Use the Faculty Homepage (CS_SSR_FC_STARTPG_FL_GBL) to access self-service transactions using the fluid user interface.
Navigation:
On a mobile device, the Fluid home appears when you first sign in. On a desktop or laptop, access the Fluid home by selecting Fluid Home under the main menu or the NavBar.
The default homepage title appears at the top of the homepage. If the Faculty Homepage isn't your default homepage, select the title of the default homepage, then select Faculty Homepage from the list that appears.
Tiles on the Faculty Homepage
Tile Name Description
Faculty Center
Select this tile to:
  • View teaching schedules.
  • Access the class roster.
  • Access the grade roster.
