Setting Up Ethnicity in the System
You must ensure that your system is set up to correctly populate ethnicity information during the TS130 and TS189 posting processes. To do so:
  • Change your internal mapping values for ETHNIC_GRP on the Conversion Data Profile page (PeopleTools, and then EDI Manager, and then Convert EDI/PeopleSoft Code, and then Conversion Data Profile) for the EDI Convert Profile ID of EDI_CONV.
  • Verify that the new values reflect those you defined for ethnic groups on the Ethnic Groups page (Set Up Common Objects , and then Product Related, and then Workforce Administration, and then Ethnic Groups).
This is an example of ethnic groups defined on the Conversion Data Profile page:
This is an example of ethnic groups defined on the Conversion Data Profile page.
Example of ethnic groups defined on the Conversion Data Profile page
