GL Interface Processing Using a Third-Party or Legacy General Ledger System
Student Financials provides an extra field for you to use to enter chart of accounts data on your item types, course or class fees, and cashiering tenders or targets. You can use the ChartFields (ACCOUNT, DEPTID, and so on) to enter your chart of accounts information.
Alternatively, Student Financials provides a 50-character field called External GL Chart Field (field name EXT_GL_CHARTFLD) that you can use to enter chart of accounts data. To enable this field, you must signify to the system that you are not using PeopleSoft or Oracle General Ledger. To indicate that you are not using PeopleSoft or Oracle General Ledger, clear the General Ledger check box on the Installation Table page and select Others as the financial system on the SF Installation page. After you clear this check box and complete setup on the SF Installation page, pages that usually display the ChartFields for data entry display instead—or, in some instances, also—the External GL ChartField field.
Using the External GL Chart Field does have some limitations. The system does not perform any editing against this field. In addition, the ChartField validation process does not check the contents of the External GL Chart Field to ensure that you have supplied valid chart of accounts information for each item type, course/class fee, and cashiering tender/target.
Even if you are not using PeopleSoft General Ledger, you must populate the GL setup tables (except the ChartField definition tables) before you can use the GL Interface or Cashiering GL Interface processes.
