Awarding Body Role
Child Entities: None
Each entity is uniquely identified by the single Awarding Body ID field. In cases where multiple entities were previously reported and one or more no longer apply, extract entities are created with Entity Status of Delete.
Field
For each Awarding Body Role field extract record for the return with a Derived Value, the record is compared with the corresponding submitted data (MST) record:
  • If the Derived Value of the field is NULL ERROR, set Field Status to Error.
  • If the combination of Institution, Qualification ID, Awarding Body ID and Field doesn't exist in the submitted data record, set Field Status to New.
  • If the combination exists in the extract record and the Entity Status in the most recent submitted data record is Delete, set Field Status to New.
  • If the Reported Value in the extract is different to the Reported Value in the most recent submitted data record, set Field Status to Amended.
  • Set Field Status to Unchanged, that is, Reported Value in the extract is the same as in the most recent submitted data record.
Entities
For each Awarding Body Role entity extract record for the return, the record is compared with the corresponding submitted data (MST) record:
  • If at least one field has Field Status of Error, set Entity Status to Error.
  • If the combination of Institution, Qualification ID and Awarding Body ID doesn't exist in the submitted data record, set Entity Status to New.
  • If the combination exists in the extract record and the Entity Status in the most recent submitted data record is Delete, set Entity Status to New.
  • If there are one or more Field extract records with Field Status of New or Amended, set Entity Status to Amended.
  • Set Entity Status to Unchanged, that is, either there are no fields or all the fields have Field Status of Unchanged.
  • For any existing entities in extract where the Awarding Body ID for the entity doesn't appear in the submitted data record, create a new entity using the Awarding Body ID with Entity Status of Delete. Create a new field extract record for AWARDINGBODYID with Field Status of Delete.
