Securing ChartFields for PeopleSoft Project Costing
This topic discusses the components in PeopleSoft Project Costing that support ChartField Security.
Project Costing excludes the Project ID field from ChartField Security because it considers the Project ID to be a Project Costing identifier field and not a project ChartField. Therefore, if the Project ID field is included in ChartField Security, then Project Costing behaves as though the Project ID field is not part of ChartField Security.
Important:
If you are using ChartField Security for the Budget Plan and Budget Detail components, the budget amount may not reflect the full amount. This is because ChartField Security filters out the unauthorized values, which are not reflected in the budget amount.
The following table lists the components in PeopleSoft Project Costing that support ChartField Security:
Component Component Description
EE_PCBUD_DRILL
Entry Event Budget Drill Down
INTERFACE_RESOURCE
Review Transaction Details
INTFC_PROJ_EXPRESS
Add Resources
KK_XCP_PC1
Project Journal Exceptions
KK_XCP_PC5
Project Costing Budget
PC_ACCTG_JNL_COMP
Accounting History Component
PC_ACCTG_LN_COMP
Project Accounting Line
PC_ADJ_ACCT_ASSGN
Trans Adjust Account Assignment
PC_AM_APPROVE
Approve review assets
PC_AM_DEFN
Project Costing Asset Definition
PC_AM_DEFN_INQ
Project Costing Asset Definition Inquiry
PC_AM_EXPRESS
Project Costing Asset Management Express
PC_AM_RESOURCES
Assign Resources to an Asset
PC_BUD_DETAIL
Project Budget Detail
PC_FND_DIST
Funds Distribution Source
PC_FND_DIST_LN
Funds Distribution Target
PC_FND_INTFC_EXCPT
Funds Budget Exceptions
PC_FND_UNAPPL_BAJ
Project Billing Adjustments
PC_KK_INTFC_EXCEPT
Review Commitment Control
PROJECT_EXPRESS
Project Resource
PROJ_RES_ARCH
Resource Archive Detail
PROJ_SUM_ARCH
Resource Archive Summary
RESOURCE_ADJUST
Resource Adjustment
TIMELABOR_INTFC
Time Labor Interface
