Using a Single Entry Event Code in Multiple Documents or Products
To use an entry event code in multiple documents or for multiple products, you must identify each process and its steps in the entry event code definition. Using the PeopleSoft procure-to-pay process as an example, you can enter an entry event code one time in the requisition document. It then flows through the entire process creating entry event transactions for each document. Before an entry event code can successfully move between documents and products, you first must set it up to run for each of the processes in the procure-to-pay cycle.
The PeopleSoft procure-to-pay cycle consists of several documents and processes. Entry event processing uses the following processes:
  • REQPOST
  • POPOST
  • VCHRPOST
  • PAYMENT
You must set up an entry event code and associate it with all four processes.
See Entry Event Code Definition Page.
Example of Defining One Entry Event Code to Use with Multiple PeopleSoft Applications
Here is an example of how to define an entry event code for multiple PeopleSoft applications:
  1. Set up the PROCURE entry event code.
    Term Definition
    Entry Event
    PROCURE
    Description
    Requisition to Cash Clearing
  2. In the Entry Event Process group box, add the REQPOST process.
    Term Definition
    Entry Event Process
    REQPOST
    Effective Date
    01/01/1900
    Status
    A
  3. In the Entry Event Step group box, add the REQPOST step.
    Term Definition
    Entry Event Step
    REQPOST
    Account
    696800 (example)
    Source Record Jrnl Template
    Not applicable (NA)
    Journal Template
    EE_PURCH
  4. In the Offset Accounts group box, add the preencumbrance and general expenses offset accounts.
    Term Definition
    DR/CR
    DR
    Account and Short Desc
    696700 (example) - Preenc Res
    DR/CR
    CR
    696500 (example) - GenExpOffs
  5. In the Entry Event Process group box, add the POPOST process.
    Term Definition
    Entry Event Process
    POPOST
    Effective Date
    01/01/1900
    Status
    A
  6. In the Entry Event Step group box, add the POPOST step.
    Term Definition
    Entry Event Step
    POPOST
    Account
    696800 (example)
    Select if a source record journal template exists.
    Journal Template
    EE_PURCH
  7. In the Offset Accounts group box, add the encumbrance and general expenses offset accounts.
    Term Definition
    DR/CR, Account, and Short Desc
    DR, 696600 (example), Enc Res
    CR, 696500 (example), GenExpOffs
  8. In the Entry Event Process group box, add the VCHRPOST process.
    Term Definition
    Entry Event Process
    VCHRPOST
    Effective Date
    01/01/1900
    Status
    A
  9. In the Entry Event Step group box, add the ACCRUAL step.
    Term Definition
    Entry Event Step
    ACCRUAL
    Account
    696800 (example)
    Select this option.
    Journal Template
    NA
  10. In the Offset Accounts group box, add the general expenses and accounts payable offset accounts.
    Term Definition
    DR, 696500 (example), GenExpOffs
    CR, 200000 (example), Accts Paybl
  11. In the Entry Event Process group box, add the PAYMENT process.
    Term Definition
    Entry Event Process
    PAYMENT
    Effective Date
    01/01/1900
    Status
    A
  12. In the Entry Event Step group box, add the PAYMENT step.
    Term Definition
    Entry Event Step
    PAYMENT
    Account
    NA
    Select this option.
    Journal Template
    NA
  13. In the Offset Accounts group box, add the accounts payable and bank disbursement offset accounts.
    Term Definition
    DR, 20000 (example), Accts Paybl
    CR. 10006 (example), UBANK Disb
