Implementing PeopleSoft Asset Lifecycle Management
PeopleSoft provides a set of documentation components that complement each other to present all the information you need to implement PeopleSoft Asset Management.
To implement PeopleSoft Asset Management, you will find the information required to set up the tables and options used by PeopleSoft Asset Management and the other PeopleSoft ALM products in this documentation as well as the following resources:
PeopleSoft Application Fundamentals
PeopleSoft Global Options and Reports
PeopleSoft IT Asset Management
PeopleSoft Maintenance Management
PeopleSoft Lease Administration
Because the information you may need to fully implement PeopleSoft Asset Management involves more than one PeopleSoft product, you need to refer to the Getting Started topic in each product document for specific implementation and integration information.
Use the PeopleSoft Applications Fundamentals product documentation to find detailed information about the following functionality and processes:
Defining financials and supply chain management common definitions
Setting installation options for PeopleSoft applications
Defining user preferences
Securing your system
Defining and using ChartFields
Editing ChartField combinations
Configuring ChartFields
Summarizing ChartFields using trees
Using entry events
Using alternate accounts
Defining accounting calendars
Setting up ledgers
Using journal generator
Using interunit and intraunit accounting and ChartField inheritance
Processing allocations
Setting up on-demand processing
Use the PeopleSoft Asset Lifecycle Management Fundamentals product documentation to find detailed information about setting up the following functionality and processes:
Establishing asset management business units and cash generating units
Establishing asset processing, including defining asset attributes, profiles, ownership and reporting options
Setting up accounting entry and financial processing
Setting up depreciation processing
Setting up tax processing and tax reporting
Integrating with other products
Configuring background processing for assets
