Understanding General Ledger Subsystem Reconciliation Integration
The General Ledger subsystem reconciliation component enables you to compare accounting transactions posted in the subsystem with General Ledger balances. The loader summarizes transactions by General Ledger business unit, fiscal year, accounting period, ledger, selected ChartFields, and system source. Subsystem transactions are categorized as either distributed or not distributed. General Ledger journal transactions are categorized as either posted or not posted. This enables you to check the integrity of the journal entries in General Ledger by verifying that no discrepancies occurred between subsystems and the General Ledger.
The General Ledger subsystem reconciliation component provides insight into the Asset Management subsystem for documents that have not been fully processed. Subsystem Reconciliation reporting allows you to report on individual documents within a subsystem and review vital status fields that may identify why a document has not been fully processed and posted to the general ledger. The inquiry is based upon data that is loaded through the Subsystem Reconciliation Loader process (GL_RECN), which maintains a status table that keeps a record of the date and time of last processing by Business Unit, System source, fiscal year, and accounting period.
The Asset Management integration with General Ledger subsystem reconciliation enables you to access and analyze Asset Management subsystem data using the following pages:
GL Reconciliation Inquiry page
Reconciliation Overview page
Subsystem Document page
Reconciliation by System Source (Reconciliation by System Srce) page
Reconciliation by ChartFields page
To help facilitate Asset Management integration with the General Ledger subsystem reconciliation component, PeopleSoft provides the AM_PENDING source document, which enables you to view and report on Asset Management subsystem data for documents that have not been fully processed. The AM_PENDING source document captures asset transactions pending accounting entry creation. Specifically, open transaction assets (Open_Trans) with a Calc_Dist_Status of ‘P’ (to be processed) are captured. Additionally, the source document defines the path and keyfields to use when performing drill down analysis to source system documents from the GL Reconciliation Inquiry page.
See:
PeopleSoft General Ledger: Reviewing Subsystem Reconciliation Data
PeopleSoft Global Options and Reports: Running the Subsystem Reconciliation Loader Process (GL_RECN)
