Accounting Entry Templates
The accounting entry template is the central table that the system uses to create accounting entries, which are the basis for general ledger journals. The accounting entry template defines accounting entry types based on asset category, cost type, transaction type, transaction code, and accounting entry template ID. For each accounting entry type, you specify:
  • The accounts to use during accounting entry.
  • The journal template to use for recording actual transactions.
  • The budget journal template to use to record budget transactions.
When you add an accounting entry template in PeopleSoft Asset Management, the system populates it with standard accounting entry types (distribution types), based on the asset category, cost type, and action that is specified for all supported features that require accounting types.
If impairment and revaluation options are enabled at the installation level, you can specify within the cost type definition if you want to enable a given cost type for impairment or revaluation processing. If enabled, the system displays the appropriate impairment and revaluation related accounts at the Accounting Entry Template level.
Use the features within the Accounting Entry Template ID component to define accounting entry template IDs that include or exclude the appropriate accounting entry (distribution) types for each type of transaction. The accounting entry template IDs can be associated with business unit-level features such as the Book Code feature, the Derogatory Depreciation feature, the Like Kind Exchange feature, and the Revaluation feature.
Accounting entry types are delivered with the PeopleSoft system, and each asset event has an associated set of accounting entry types. For each combination of category, cost type, transaction code, and accounting entry template ID, you must set up an accounting entry template for the following transaction types:
Transaction Type Description
AA
Accumulated amortization
ADD
Additions.
ADJ
Adjustments.
LN
Lease incentive.
LR
Lease remeasurement
TRF
Transfers.
RCT
Recategorizations.
DPR
Depreciation expense.
PDP
Prior period depreciation.
RE
Rent expense.
RET
Retirements (also used for processing reinstatements).
RT
Rent expense contra.
LPY
Lease payments.
INF
Inflation adjustment.
LEX
Lease expense.
If you enter a transaction into the system with a combination of category, cost type, transaction code, and accounting entry template ID for which no accounting entry template exists, the accounting entry process will fail the next time it is run.
DPR and PDP transaction types are used only on an accounting entry template with a blank transaction code.
Accounting Entry Types (Distribution Types)
Asset Management creates accounting entries by using standard accounting entry types (distribution types), based on the asset category, cost type, and action that is specified for all supported features that require accounting entry types. The following tables list the accounting distribution types that are associated with each accounting entry feature.
Following are the distribution types for the ADD (addition) transaction type (if there is no 'X' for a distribution type (blank), that type is not applicable for the listed feature):
Type Description Basic Expensed Asset Lease Derogatory Like Kind Exchange Revaluation
AD
Accumulated Depreciation
X
X
AP
Contra Asset
X
X
X
DD
Accumulated Derogatory Depreciation
X
DE
Depreciation Expense
X
X
DR
Derogatory Depreciation Reversal
X
DX
Derogatory Depreciation Expense
X
EX
Expense
X
FA
Fixed Asset
X
X
IV
Investment Property
X
X
IX
Investment Property Accumulated Depreciation Adjustment
X
X
LO
Lease Obligation
X
TI
Trade In
X
X
UR
Unrecognized Gain/Loss
X
X
RL
Recognized Loss
X
X
PR
Provision for Revaluation
X
Following are the distribution types for the ADJ (adjustment) transaction type:
AD
X
X
AP
Contra Asset
X
X
X
DD
X
DE
X
X
DR
X
DX
X
EX
Expense
X
FA
Fixed Asset
X
X
IV
Investment Property
X
X
LO
Lease Obligation
X
PG
Investment Property Gain
X
X
PL
Investment Property Loss
X
X
PR
X
RD
Reversal of Depreciation
X
IM
Impairment Loss
X
X
IN
Impairment Contra
X
Here are the distribution types for the TRF (transfer) transaction type:
Type Description Basic Lease Derogatory Like Kind Exchange Revaluation
AD
X
X
DD
X
DR
X
DX
X
FA
Fixed Asset
X
X
IV
Investment Property
X
X
PR
X
RC
Provision for Revaluation Contra
X
Here are the distribution types for the RCT (recategorize) transaction type:
AD
X
X
DD
X
DR
X
DX
X
FA
Fixed Asset
X
X
IV
Investment Property
X
X
PR
X
RC
X
Here are the distribution types for the RET (retire) transaction type:
AD
X
AP
Contra Asset
X
BI
Proceeds to Billing Account
X (If Billing is installed)
CA
Proceeds
X
DD
X
DR
X
DX
X
FA
Fixed Asset
X
GA
Gain
X
GL
Loss
X
IV
Investment Property
X
LG
Lease Guarantee Contra
X
LO
Lease Obligation
X
LU
Lease Guarantee Obligation
X
MA
Mortgage - Others
X
ML
Mortgage - Comp
X
NV
Net Book Value
X
PR
X
RC
X
RD
X
RG
Recognized Gain
X
RM
Removal Contra
X
SL
Sales of Fixed Asset
X
TI
Trade In
X
UG
Unrealized Gain
X
UL
Unrealized Loss
X
Here are the distribution types for the DPR (depreciation) transaction type:
AD
X
X
DD
X
DE
X
X
DR
X
DX
X
RC
X
RD
X
Here are the distribution types for the PDP (prior period depreciation) transaction type:
AD
X
DD
X
DE
X
DR
X
DX
X
RC
X
RD
X
Here are the distribution types for the LPY (lease payment) transaction type:
LC
Lease Interest Contra
X
LI
Lease Interest
X
LO
Lease Obligation
X
LP
Lease Obligation contra
X
VE
Variable Lease Expense Debit
X
VC
Variable Lease Expense Contra
X
Here are the distribution types for the INF (inflation) transaction type:
IA
Inflation Accum Depr
X
IB
X
IC
Inflation Cost Adjustment
X
ID
X
IG
Inflation Gain
X
IL
Inflation Loss
X
IP
Inflation Period Depr
X
IQ
X
IY
Inflation YTD Depr
X
IZ
Inflation YTD Depr
X
See Asset Lifecycle Management Fundamentals: Defining Accounting Entries.
See Asset Lifecycle Management Fundamentals: Creating PeopleSoft Asset Management Business Units.
