Asset Management WorkCenter page
Use the Asset Management WorkCenter page (AM_WORKCENTER_FL) to access the My Work, Links, Queries, and Reports/Processes pagelets using the PeopleSoft Fluid User Interface.
Navigation:
Select the Asset Management WorkCenter tile.
This example illustrates the fields and controls on the Fluid Asset Management WorkCenter Page as displayed on a desktop. You can find definitions for the fields and controls later on this page.
This example illustrates the fields and controls on the Fluid Asset Management WorkCenter Page as displayed on a smartphone. You can find definitions for the fields and controls later on this page.
Asset Management WorkCenter Page (Fluid) on Mobile
On a smartphone (small form factor) only the My Work pagelet is displayed, and only the processes or exceptions with a count are visible.
Field or Control Description
Workcenter Personalize icon
(Personalize icon)
Click the Personalize icon to access these options:
Refresh Icon
(Refresh icon)
Click the Refresh icon to apply updates to personalizations or filters.
Update Selected Rows
(Update Selected Rows)
Click to activate the checkboxes and Actions button. Select the checkboxes to select one or more rows from the list and perform the related actions in bulk.
Actions
(Actions)
Click to perform the related actions available for the selected items.
Filter
(Filter)
Click to refine filter criteria.
Download to Excel
(Download to Excel)
Click to download data from the current grid into an Excel file.
Find
(Find)
Click to search for a desired value in the current grid.
Sort
(Sort)
Click to sort current grid data by one of the grid columns.
Process Monitor
This link takes you to the Process List page, where you can view the status of submitted process requests.
