PeopleSoft Asset Management Integration Touchpoints
Asset Management is the core product of the PeopleSoft Asset Lifecycle Management suite, which also includes:
PeopleSoft IT Asset Management
PeopleSoft Maintenance Management
PeopleSoft Lease Administration
To use PeopleSoft Asset Management to full advantage, it is also important to understand the points of integration between PeopleSoft Asset Management and the other PeopleSoft applications that you have purchased, such as:
PeopleSoft General Ledger.
PeopleSoft Billing.
PeopleSoft Budgeting.
PeopleSoft Purchasing.
PeopleSoft Project Costing.
PeopleSoft Payables.
PeopleSoft Strategic Sourcing.
Third-party applications for computer-aided facilities management, tax provider systems applications.
Because applications share information, you must plan to work closely with the implementation teams that install other PeopleSoft applications to ensure that PeopleSoft provides the full functionality and efficiency that your company requires.
You can find more information about integration considerations in the implementation topics in this documentation. Supplemental information about third-party application integrations is on Oracle's My Oracle Support web site:
PeopleSoft Asset Management integrates with these PeopleSoft applications:
This graphic illustrates the applications with which PeopleSoft Asset Management integrates.
