Populating Asset Management Tables with Asset Data
This data conversion step populates PeopleSoft Asset Management database tables with the data that you just loaded into INTFC_FIN, INTFC_PHY_A, and INTFC_PHY_B by running the Transaction Loader Application Engine, AMIF1000.
The Transaction Loader is also used for mass transactions. After performing a mass change, run this Application Engine to create entries in Asset Management tables.
You must run the Transaction Edit program (AMIFEDIT) before running the Transaction Loader, especially at conversion time. The Transaction Edit program performs edit checks on the data fields that you specify to help ensure that the information you load into PeopleSoft Asset Management is correct. Review the data that is loaded into INTFC_FIN, INTFC_PHY_A, and INTFC_PHY_B and look carefully at the Transaction Loader Application Engine (AMIF1000) before you run it. You may need to change some of the data defaults that it contains.
