Understanding the Asset Management Implementation Process
To implement Asset Management, you will find the information required to set up the tables and options used by Asset Management and the other ALM products in the following resources:
PeopleSoft Application Fundamentals .
PeopleSoft Asset Lifecycle Management Fundamentals
PeopleSoft IT Asset Management
PeopleSoft Maintenance Management
PeopleSoft Lease Administration
Because the information you may need to fully implement Asset Management involves more than one PeopleSoft product, you need to refer to the Getting Started topic in the product documentation for each product for specific implementation and integration information.
Use the PeopleSoft Application Fundamentals to find detailed information about the following functionality and processes:
Defining Financials and Supply Chain Management common definitions.
Setting installation options for PeopleSoft applications.
Defining user preferences.
Securing your system.
Defining and using ChartFields.
Editing ChartField combinations.
Configuring ChartFields.
Summarizing ChartFields using trees.
Using entry events.
Using alternate accounts.
Defining accounting calendars.
Setting up ledgers.
Using journal generator.
Using interunit and intraunit accounting and ChartField inheritance.
Processing allocations.
Setting up on-demand processing.
Use the Asset Lifecycle Management Fundamentals to find detailed information about the following functionality and processes:
Establishing asset business units and cash generating units
Establishing asset processing, including defining asset attributes, profiles, ownership and reporting options.
Setting up accounting entry and financial processing.
Setting up depreciation processing.
Setting up tax processing and tax reporting.
Integrating with other products.
Using delivered workflows for assets.
Configuring background processing for assets.
Working with the Loader Table Data Dictionary.
See the product documentation for:
PeopleSoft Global Options and Reports
PeopleSoft Financials, Enterprise Service Automation, Asset Lifecycle Management Portal Packs
PeopleSoft Billing
PeopleSoft General Ledger
PeopleSoft Payables
PeopleSoft Project Costing
PeopleSoft Purchasing
PeopleSoft Strategic Sourcing
