Setting Permissions
PeopleSoft delivers the EOCM1500 (partner users), and EOCM6500 (enterprise catalog managers) permission lists. These permission lists enable users to perform specific catalog management activities. Permissions are preconfigured as:
Component interfaces.
PeopleSoft Query access groups and profiles.
To set the permissions for these permission lists:
Select PeopleTools, Security, Permissions & Roles, Permission Lists.
Select a permission list.
Access the Component Interfaces page.
Select EOCM_CATEGORIZE_CI and assign full access to all methods.
Access the Query page.
Make sure that the access group permissions are set to with these options:
The tree name is QUERY_TREE_EOCM.
The access group is EOCM_ACCESS_GROUP.
The Accessible check box is selected.
For the query profile, make sure that the Only allowed to run queries check box is selected.
If you create permission lists for partner users and enterprise catalog managers, you must also perform these steps for those lists.
See the product documentation for PeopleTools: Security Administration
