Setting Process Definition Options
To define process definition options for the EOCM_TRDP_AE process:
  1. Select PeopleTools, Process Scheduler, Processes.
  2. Select the EOCM_TRDP_AE process.
  3. Access the Process Definition Options page.
  4. Enter the following information:
    Field or Control Description
    Server Name
    Enter a valid Process Scheduler server name.
    Recurrence Name
    Select EOCM Daily Partner Cleanup.
    Component
    Select AE_REQUEST.
    Process Groups
    Select EOCMALL.
