Delivered Archive Procedures for Commitment Control
Three archive procedures are delivered for the archiving of commitment control records and tables:
CC Activity Archive
CC Journals Archive
CC Ledgers Archive
| Archive Procedure | Tables Archived | Prompts and Inclusion or Exclusion Rules |
CC Activity Archive: The Archive Preprocess Application Engine process (KK_AR_AC_PRE) must be run to update the Process Instance of the KK_SOURCE_HDR for rows that are to be archived, based on the Archive Query selection criteria, which can be user-defined, and the implicit rules described for the commitment control activity tables. No post-process is necessary. |
Archive Query prompt selection criteria:
Inclusion and Exclusion Rules:
Commitment Control Journals: The KK_BUDGET_HDR is the base table and the KK_BUDGET_LN is the nonbase table. No preprocess or post-process are required. |
Inclusion and Exclusion Rules (user-configurable through the Archive Queries), for example, you require that all journals have a status of posted or unposted. |
Commitment Control Ledgers: No preprocess or post-process is necessary. The LEDGER_KK rows that are to be archived are based on the Archive Query selection criteria, which can be user-defined. |
Inclusion and Exclusion Rules (all are user-configurable through the Archive Queries):
These commitment control archive procedures are delivered as sample data with all the necessary history tables, preprocesses, archive object definitions, query definitions, and template definitions necessary to archive commitment control activity, ledgers, and journals.
If other archiving needs should arise, you can modify or create new objects using the Data Archive Manager and Application Designer as described in PeopleSoft PeopleTools documentation.
See PeopleTools: Data Administration Tools, "Using PeopleSoft Data Archive Manager"
The following lists the product KK Source Header Table name for each Source Transaction.
| Source Transaction | Product KK Source Header Table |
AP_VOUCHER |
KK_SHDR_APVCHR |
AP_ACCT_LN |
KK_SHDR_APACTLN |
AP_ACCTDSE |
KK_SHDR_APACTLN |
AP_ACTDSEC |
KK_SHDR_APACTLN |
AP_VCHR_NP |
KK_SHDR_APVCHR |
AR_MISCPAY |
KK_SHDR_ARMPAY |
AR_REVEST |
KK_SHDR_ARRVEST |
BI_INVOICE |
KK_SHDR_BIINV |
CM_TRNXTN |
KK_SHDR_CMTRN |
EX_EXCLOSE |
KK_SHDR_EXSHEET |
EX_EXSHEET |
KK_SHDR_EXSHEET |
EX_TRVAUTH |
KK_SHDR_EXTRATH |
GENERIC |
KK_SHDR_GEN |
GL_BD_JRNL |
KK_SHDR_GLJRNL |
GL_JOURNAL |
KK_SHDR_GLJRNL |
GM_FA |
KK_SHDR_GMFA |
GM_FA_UPG |
KK_SHDR_GMFA |
HR_PAYROLL |
KK_SHDR_HRPAY |
PC_BUDGET |
KK_SHDR_PCJRNL |
PC_JOURNAL |
KK_SHDR_PCJRNL |
PO_POENC |
KK_SHDR_POENC |
PO_POENCNP |
KK_SHDR_POENC |
PO_PROCARD |
KK_SHDR_POCARD |
PO_RAENC |
KK_SHDR_PORA |
PO_RAEXP |
KK_SHDR_PORA |
REQ_PRECNP |
KK_SHDR_REQ |
PEQ_PREENC |
KK_SHDR_REQ |
