Restoring Commitment Control Records and Tables
This section provides an overview of data restoration and lists the page used to restore data.
To restore commitment control records and tables, use the Archive Data to History component (PSARCHRUNCNTL).
Page Used to Restore Commitment Control Records and Tables
| Page Name | Definition Name | Usage |
Archive Data to History Page |
PSARCHRUNCNTL |
Select an archive ID (template) and the batch number for the process run of the data that you want to restore. See the product documentation for PeopleTools: System and Server Administration, Data Archive Manager |
Understanding Restoring Commitment Control Records and Tables
The Selection option on the Archive Data to History page places a copy of the data located in the active source records and tables in the history tables and the Delete option removes the archived data from the active source database tables. If you delete data from the source tables in error, you can restore the data from the history tables by using the Rollback option on the Archive Data to History page.
You cannot restore selected parts of the data from the history tables because the process restores all data for a specific archive ID (template) and process run. For example, you cannot specify that you want to restore data for a particular transaction to the source tables.
While you can restore data to the source tables from the history tables, the compatible structure of the source and history tables must be maintained over time to successfully restore data.
Important:
After you delete data from the history tables, you cannot restore the data to the active source database tables unless you maintain flat files as backup and manually restore the data to the history tables from the flat file and then to the active database tables from the history tables.
