Running the Commitment Control Security Application Engine Process
Before your security rules and assignments can take affect, you must run the Commitment Control Security Application Engine (KSEC_FLAT) process to create the tables used by the system to check security access. You can view the results of the process on the Commitment Control Security (GLX8572) report.
Pages Used to Run the Commitment Control Security Process
| Page Name | Definition Name | Usage |
Request Build Commitment Control Security Page |
KSEC_AE_RNCNTL |
Request a run of the Commitment Control Security Application Engine (KSEC_FLAT) process. This process creates the security rules that are evaluated during transaction entry. No security rules are in effect until you run this process. Ensure that you activate security events that you want to use prior to running this process. There are no request parameters required on this page. |
Commitment Control Budget Security Report) Page |
RUN_GLC8572 |
Request a run of the Commitment Control Security (GLX8572) report. This BI Publisher report shows the security rules assigned to each user ID and permission list, along with details about the budgets and security events included in the security rules. There are no request parameters required on this page. |
Commitment Control Budget Security Report (BI Publisher) Page |
RUN_GLC8572 |
Request a run of the Commitment Control Security (GLX8572) report. This BI Publisher report shows the security rules assigned to each user ID and permission list, along with details about the budgets and security events included in the security rules. |
