Setting Up Entry Events to Process Upward and Downward Adjustments
The Commitment Control budget processor recognizes a budget as expired when the expired date is attained for that budget. Additionally, it recognizes a budget as unexpired if all of the previously designated criteria are met. Entry event uses this information to trigger creation of upward or downward adjustments derived from the difference between the accumulated voucher amounts and the applicable purchase order or orders for the expired budgets. The entry event processor uses the steps defined for expired or unexpired upward and downward adjustments to create accounting entries.
See Application Fundamentals: Upward and Downward Adjustments.
See Application Fundamentals: Using Entry Event Codes for Upward and Downward Adjustments in Unexpired and Expired Funding
