Mapping Enterprise Data Flow
You need to determine the flow of data into and out of PeopleSoft Contracts. Mapping which applications integrate with PeopleSoft Contracts and how to carry out that integration helps you with setup decisions.
Here are some questions to help with this mapping:
What applications integrate with PeopleSoft Contracts?
Are these applications currently implemented?
If not, when are they scheduled for implementation?
What do you want to track in your PeopleSoft Contracts system?
