Displaying Scrap and Standard Earned Conversion Costs
Periodically, you want to monitor scrap and earned conversion costs that are associated with production. Viewing this information enables you to see how the manufacturing floor is performing. PeopleSoft provides you with the ability to view scrap and earned conversion costs against production IDs and production schedules in the production environment.
Earned conversion costs are calculated for:
Field or Control Description
Labor or Machine Setup
Setup time converted to hours multiplied by the labor or machine setup rate. Setup is earned when the first completion is recorded for the operation or when the SetUp Complete check box is selected during the recording of completions and scrap for an assembly.
Labor or Machine Fixed Run
Fixed run time converted to hours multiplied by the labor or machine fixed run rate. Fixed run is earned when the first completion is recorded for the operation.
Labor or Machine Run
When the run labor or machine rate is in terms of a rate per hour, the run times (or run rates) are converted to an amount per hour multiplied by the quantity completed, which is then multiplied by the labor or machine rate. When the labor or machine rate is in terms of an amount per unit, the per-unit amount is multiplied by the quantity that is completed.
Labor or Mach Post Production
Post production time converted to hours, multiplied by the labor or machine post production rate. Post production time is earned when the Post Production check box is selected during the recording of completions and scrap for an assembly or when a production ID or schedule is closed for accounting.
Pages Used to Display Scrap and Earned Conversion Costs
Scrap List by Operation Page
SF_SCRAP_INQ_OP
After entering data in the Production Selection page, you can view scrap information by operation sequence for a specific production ID or production schedule.
Scrap Cost Detai Pagel
SF_SCRAP_INQ
After entering data in the Production Selection page, you can view detailed scrap costs for the production ID or schedule broken down by operation sequence.
Earned Conversion Cost by Operation Page
SF_EARNCON_INQ_OP
After entering data in the Production Selection page, you can view conversion cost information by operation sequence for a specific production ID or production schedule.
Earned Conversion Cost Detail Page
SF_EARNCON_INQ
After entering data in the Production Selection page, you can view earned conversion cost detail for production.
