Deal Review
This section discusses the Deal Review workflow.
Description
Information Type Description
Event Description
The system activates this workflow when the following conditions are met: the Enable Deal Preview/Approve check box is selected on the Treasury Options page (BUS_UNIT_OPT_TR), and the Approval Required option is selected on the Instrument Detail page (INSTR_DETAIL_TR).
Action Description
Routes names of deals requiring approval to an assigned user's worklist.
Notification Method
Worklist
Active or Inactive
Active
Workflow Objects
Approval Rule Set
None
Business Process
Capturing Deals (TR_CAPTURE_DEALS)
Activity
Enter Deal Terms
Role
None
