Review at Confirmation
This section discusses the Review at Confirmation workflow.
Description
| Information Type | Description |
Event Description |
The system activates this workflow when the following conditions are met: the Enable Deal Preview/Approve is selected on the Treasury Options page (BUS_UNIT_OPT_TR), and the Review at Confirmation check box is selected on the Instrument Detail page (INSTR_DETAIL_TR). |
Action Description |
The system sends an email listing deals with invalid confirmations. |
Notification Method |
Worklist |
Active or Inactive |
Active |
Workflow Objects
Approval Rule Set |
None |
Business Process |
Capturing Deals (TR_CAPTURE_DEALS) |
Activity |
Enter Deal Terms |
Role |
None |
