Understanding Deal Review and Approval
You facilitate deal reviews and approvals by selecting the appropriate Deal Approvals check boxes on the Treasury Options page. For the deal approval options you select, you choose either Workflow or Approval Framework. At deal capture and deal confirmation, if the deal meets certain criteria, the system automatically sends notifications to defined users and their worklists.
