Related Product Documentation
The PeopleSoft Electronic Data Interchange provides you with implementation and processing information for your PeopleSoft system. However, additional, essential information describing the setup and design of your system resides in companion documentation. The companion documentation consists of important topics that apply to many or all PeopleSoft applications across the Financials, Enterprise Service Automation, and PeopleSoft Supply Chain Management product lines. You should be familiar with the contents of this documentation.
The following companion documentation apply specifically to Electronic Data Interchange:
PeopleSoft Application Fundamentals
PeopleTools : Integration Tools
PeopleSoft Enterprise Components
