Configuring Your Document Management System
The Documentum server (document database) must first be installed and accessible from the PeopleSoft NT server (UNIX is not supported). When accessing Documentum functions through a PeopleSoft Documentum-enabled internet page, the application server accessed using the PeopleSoft page must contain the appropriate Documentum runtime libraries and access to the Documentum server.
Important:
The Documentum integration between PeopleSoft and Documentum may require customization as it is no longer a supported integration.
If you have any questions regarding the compatibility of your Documentum system with PeopleSoft Engineering, please contact your account manager.
Prior to using PeopleSoft Engineering with Documentum:
Verify that Documentum is installed and that specific Documentum library files (DLLs) are installed on the application servers.
Define Documentum options by using the navigation.
