Making BOM Mass Changes Using Mass Maintenance
PeopleSoft Engineering enables you to make mass engineering or manufacturing BOM changes, using the mass maintenance feature. This enables you to:
Create mass maintenance codes that enable you to add, change, and obsolete component items on several bills of material in a single process.
Execute changes in a Verify only or Verify and apply change mode.
Optionally 'stage' BOM changes so that changes can be reviewed and modified online prior to moving mass changes to MBOMs or EBOMs.
Apply changes to BOMs, with or without the use of ECOs.
Apply changes to engineering BOMs or manufacturing BOMs.
Make changes to manufacturing BOMs by transferring them to the engineering workbench and then transferring them back or by making these changes directly to the manufacturing BOMs, if wanted.
Optionally automatically create revisions for BOMs included within an engineering change (without ECOs).
