Using Transaction Codes
The system uses the following transaction codes:
Transaction Code Action
0102
Load entire PO
0103
Load PO line
0104
Load PO schedule
At the child label of the message, you can indicate what you are receiving in this particular shipment by entering the appropriate code. If you specify code 0102, you must enter the PO and the business unit for the PO. If you specify 0103, you must provide the quantity, PO, unit, line number, and unit of measure (UOM). If you specify 0104, you must enter the quantity, PO, unit, line, schedule number, and UOM.
The end transaction flag (END_TRANS_FLAG) tells the system whether this message can be processed and whether the receipt can be created immediately. If the flag status is N, the data remains in the system with an incomplete status—therefore, populate this flag with Y.
