Migrating Data Using Application Data Sets
PeopleSoft Application Data Sets (ADS) are delivered for key setup data records to simplify the administration, testing, and transfer of setup data between databases. Once specific setup data is defined and tested in a testing environment, ADS helps move the data (along with their related data counterparts) easily between databases. Since the relationships between the setup data records are maintained and pre-delivered into the ADS, there are less issues to consider, especially when compared with running traditional Data Mover scripts. ADS records are delivered in PeopleSoft Expenses for:
Expense Types, Expense Type Groups, Expense Type Categories
Expense Locations, Location Amounts
Approval Workflow configuration (Approver Stages, Refinement Templates, Risk Templates)
Roles and Privilege Templates (employee & approver)
Per Diem (including Range Categories, Ranges, Per Diem Amounts, Formulas)
The data set project use these data sets in PeopleSoft Expenses to copy data from one system to another system.
| Delivered ADS to Support PeopleSoft Expenses | Record | Description |
EX_APPRVR_ASSIGN |
EX_APPRVR |
EXPENSES APPROVER ASSIGNMENTS |
EX_APPRVR_LIST |
EX_TRANS_RTG EX_TRANS_RTGLST |
EXPENSES APPROVER ROUTING LIST |
EX_APPRVR_PROF |
EX_PROF_APPRVR EX_PROF_ATTR |
EXPENSE APPROVER PROFILE |
EX_APPRVR_TYPE |
EX_APPRVR_TYPE |
EXPENSE APPROVER TYPE |
EX_EE_PRIV_TMPL |
EX_EE_PRIV_TMPL EX_EE_PRIV_CF |
EXPENSE EE PRIVILEGE TEMPLATE |
EX_LOC |
EX_LOCATION_TBL |
EXPENSE LOCATION |
EX_LOC_AMT |
EX_LOC_AMOUNT EX_LOC_AMT_DTL |
EXPENSE LOCATION AMOUNT |
EX_LOC_GRP |
EX_LOC_GRP_TBL |
EXPENSE LOCATION GROUP |
EX_LOC_AMT_TYPE_GRP |
EX_LOC_AMT_GRP EX_LOCAMT_G_DTL |
EXPENSE LOCATION AMOUNT TYPE GROUP |
EX_MERCHANT |
EX_MERCHANT_TBL |
EXPENSES PREFERRED MERCHANT |
EX_PD_CALC |
EX_PD_CALC_TBL EX_PD_CALC_DTL |
EXPENSE PER DIEM CALCULATION |
EX_PD_CATEGORY |
EX_CATEGORY_TBL |
EXPENSE PER DIEM CATEGORY |
EX_PER_DIEM_AMT |
EX_PER_DIEM_TBL EX_PER_DIEM_DTL |
EXPENSE PER DIEM AMOUNT |
EX_PER_DIEM_RANGE |
EX_RANGE_TBL EX_RANGE_DTL |
EXPENSE PER DIEM RANGE |
EX_PRIV_TMPL |
EX_PRIV_TMPL |
EXPENSE PRIVILEGE TEMPLATE |
EX_REFINE_TMPL |
EX_REFINE_TMPL EX_REFINE_DEPT EX_REFINE_EE EX_REFINE_BU EX_REFINE_TRC EX_REFINE_TYPES |
EXPENSE REFINEMENT TEMPLATE |
EX_RISK_TMPL |
EX_RISK_TMPL EX_RISK_BU EX_RISK_BUSPURP EX_RISK_DEPT EX_RISK_EE EX_RISK_AUTHAMT EX_RISK_TOTLMT EX_RISK_TRC EX_RISK_TYPLMT |
EXPENSE RISK TEMPLATE |
EX_ROLE |
EX_ROLE_TBL EX_ROLE_PRIV |
EXPENSE ROLE |
EX_ROLE_EXCEPTION |
EX_ROLE_TBL EX_ROLE_EXCP_ET EX_ROLE_EXC_ETG |
EXPENSE ROLE EXCEPTION |
EX_ROLE_EXP_TYPE |
EX_ROLE_TBL EX_ROLE_EXP_TYP |
EXPENSE ROLE EXPENSE TYPE |
EX_ROLE_VAT |
EX_ROLE_EXCP_VT |
EXPENSE ROLE VAT |
EX_TRANS_DEFN |
EX_TRANS_DEFN EX_TRANS_PROP |
EXPENSE TRANSACTION DEFINITION |
EX_TYPE |
EX_TYPES_TBL EX_TYPES_CF_TBL EX_TYPE_MERCHNT EX_TYPE_PERDIEM |
EXPENSE TYPES |
EX_TYPE_CAT |
EX_TYPE_CAT_TBL EX_TYPE_CAT_DTL |
EXPENSE TYPE CATEGORY |
EX_TYPE_GRP |
EX_TYPE_GRP_TBL EX_TYPGP_CF_TBL |
EXPENSE TYPE GROUP |
EX_TYPE_IMG |
EX_EXP_TYPE_IMG |
EXPENSE TYPE IMAGE |
