Prerequisites - Setting Up Fluid Approval Options for Expense Reports
To use PeopleSoft Fluid Approvals for approving expense reports, you must:
Implement Approval Framework for Expenses. See Understanding Approval Workflow.
Activate the EXER transaction ID within the Enterprise Components: Fluid Approval Setup - General Settings Page
Implement system-wide setup of Fluid Approval Framework, see Application Fundamentals: Application Fundamentals: Configuring Fluid Approvals
