Setting Up the Expenses WorkCenter for Fluid
To set up the Expenses WorkCenter for Fluid:
Use the Configure Pagelets component to define configuration IDs for Fluid WorkCenters.
See the Enterprise Components: Configuring Pagelets topic.
Use the Application Fundamentals: Personalize Page (Fluid) to personalize your display options for Fluid WorkCenter group boxes.
See also the Application Fundamentals: Setting Up and Personalizing PeopleSoft Fluid WorkCenters topic for additional setup pages.
