Using PeopleSoft Fluid User Interface for Expenses
PeopleSoft Fluid User Interface is an alternative to the PeopleSoft Classic User Interface, but is designed to be used on all types of devices such as smart phones, tables, laptops and desktops.
To use Expenses in Fluid, you must configure system-wide settings. See Enterprise Components: Fluid Approval Setup - General Settings Page.
Enable receipt attachments and images for expense reports from the Application Fundamentals: Installation Options - Expenses Page. To view non-image attachments, you must specify the Process Server on the Mobile Approval Options page for report node setup. See Enterprise Components: Fluid Approval Setup - General Settings Page
When accessing a PeopleSoft Fluid page, the system detects the device you are using and renders the appropriate page. The Expenses homepage is virtually identical whether you launch from a mobile phone or a tablet and includes the same functionality. The only difference is that the mobile phone version is scaled to fit the smaller screen size of the mobile phone device. Select the Expenses tile to view individual tiles.
This topic discusses the tile available on the Expenses Homepage.
