Prerequisites for PeopleSoft SCM Portal Pack
Before you can view and use the pagelets in the PeopleSoft SCM Portal Pack, you must complete these steps:
Install the PeopleSoft FSCM product database.
Select Supply Chain Portal Pack on the Products page of the Installation Options. (Set Up Financials/Supply Chain, Installation Options).
Install the products on the Installation Options – Products page that supply data to the SCM Portal Pack, which include:
PeopleSoft Billing.
PeopleSoft Order Management.
PeopleSoft Promotions Management.
PeopleSoft eBill Management.
Set up PeopleSoft PeopleTools Security roles and permission lists to access pagelets.
