Using Roles and Permission Lists for the PeopleSoft ESA Portal Pack
The PeopleSoft ESA Portal Pack delivers sample roles and permission lists in the Financials database that you can use as an example to configure your security.
When you install a portal pack, pagelets are available for authorized users from the Financials database application homepage. Pagelets are assigned to specific permission lists instead of to specific roles. Therefore, when you log in, the system matches your role (that is associated with your user ID) to the appropriate permission lists to display authorized pagelets.
This table lists the enabling ESA applications and their associated pagelets and sample permission lists:
| Enabling ESA Application | Pagelet | Permission List |
PeopleSoft Enterprise Service Automation Portal Pack |
All personalization pages for the pagelets that use this permission list Media Sources Operational Threshold Alert Operational Threshold Chart |
EPCO8000 |
PeopleSoft Contracts |
All pagelets and personalization pages for PeopleSoft Contracts |
EPCA5000 |
PeopleSoft Expenses |
All pagelets and personalization pages for PeopleSoft Expenses |
EPCF1100 |
PeopleSoft Program Management |
All pagelets and personalization pages for PeopleSoft Program Management |
EPPG7100 |
PeopleSoft Project Costing |
All pagelets and personalization pages for PeopleSoft Project Costing |
EPPG7100 |
PeopleSoft Proposal Management |
All pagelets and personalization pages for PeopleSoft Proposal Management |
EPPM2000 |
PeopleSoft Resource Management |
All pagelets and personalization pages for PeopleSoft Resource Management |
EPRS6000 |
To add pagelets to your PeopleSoft homepage, click the Personalize Content link on your homepage to access a list of pagelets to which you have access, and select one or more pagelets.
To personalize the pagelet layout on your PeopleSoft homepage, click the Layout link on the homepage.
