Components Used to Produce XBRL Balance Sheets and Income Statements
To use XBRL to produce balance sheets and income statements, use the following components:
XBRL Context (XBRL_CONTEXT)
XBRL NameSpace (XBRL_SETUP_NSPACE)
XBRL Element (XBRL_ELEMENT)
XBRL Instance Template (XBRL_SETUP)
Pages Used to Produce Financial Statements Using XBRL
| Page Name | Definition Name | Usage |
XBRL Context Page |
XBRL_CONTEXT |
Define XBRL numeric contexts and specify their Effective Date and Status. PeopleSoft supports only numeric context. An XBRL context can specify reports for amounts or amounts per share.
XBRL NameSpace Page |
XBRL_SETUP_NSPACE |
Define a NameSpace alias for the NameSpace URL that provides access to the taxonomies, which are appropriate to your XBRL reports.
XBRL Element Page |
XBRL_ELEMENT |
Specify the XBRL labels and elements to be used in the production of your reports.
Setup Page |
XBRL_SETUP_TYPE |
Define the template name and specify the scope, entity information, and time span for your reports.
Report Element Page |
XBRL_RPT_ELEMENT |
Specify the elements and ChartField Value Sets that determine the items and amounts that are reported.
Create XBRL Instance Request Page |
RUN_XBRL |
Determine the dates, the report template, and the business unit or ledger set that are used to create your reports.
