Defining Approval Options at the Various Levels
When you define approval options at the source level, they override any approval handling that you specify at the ledger-group and business-unit levels. Any rules specified at the ledger level override those at the business-unit level.
You can define approval options at the:
Source level using the SOURCE component.
Ledger level using the BUSINESS_UNIT_LED component.
Business unit level using the BUS_UNIT_TBL_GL component.
See Application Fundamentals: Journal Source - Approval Options Page.
See Application Fundamentals: Ledgers For A Unit - Approval Options Page.
