General Ledger Reports: A to Z
This table lists the General Ledger reports, sorted alphanumerically by report ID.
You may see both of the terms XML Publisher (XMLP) and BI Publisher, depending on the version of your PeopleTools installation and the Bundle version of your application. As of PeopleTools 8.52, references to XML Publisher (XMLP) have changed to BI Publisher. This does not denote a change to the reports; only the naming convention has changed.
For samples of these reports, select Report Samples.
Report ID and Report Name Description Navigation Run Control Page
FIN1001
Message Log Report
Prints message logs for a process instance ID and batch report type, similar to the online query that is available for each background program. Displays job ID, program name, date, time, sequence number, logged message, and explanation for each process instance ID. (SQR)
Background Processes, and then Business Process Log Rpt
RUN_FIN1001
FIN2001
Journal Entry Detail Report
Displays all journal entries that were entered in the system for a business unit and ledger within the date range specified. Prints the journal entries in ascending ID order within the ledger and shows the journal date, the source, whether a reversal entry was created, journal status, posted date (if any), and a description. For each line that is included in the journal entry, lists the line number of the entry, the account number, a description, the department, product, and project ChartField values, and debit and credit detail. Also prints statistical information where included in a journal entry. (SQR)
General Ledger, and then General Reports, and then Print Journal Entry Detail
RUN_FIN2001
FIN2005
Journal Entry Detail Report with Attributes
This report is similar to the Journal Entry Detail Report, except that this report also lists the ChartField attribute values. (SQR)
General Ledger, and then General Reports, and then Journal Entry Attributes Rpt
RUN_FIN2005
FIN5001
Reconciliation by System Source
This report consists of detailed subsystem and General Ledger (GL) journal transactions that are aggregated to the business unit, subsystem source, ledger, account or alternate account, fiscal year, and accounting period level.
For example, it lists the data at the system source level, such as accounts payable (AP), and then lists all the activity for AP, including what was posted and not posted, for one or more selected ChartFields that appear in the data that you loaded. (SQR)
General Ledger, and then General Reports, and then GL Subsystem Reconciliation, and then Reconciliation by System Srce
RUN_FIN5001 (RUN_GLRCN_RPTS)
FIN5005
Reconciliation by ChartField report.
Lists the data based on one or more selected ChartFields that appear in the data that you loaded. Each of the subsystem amounts that fall within the ChartField combination is listed on the report along with the total amounts for the ChartFields and the related ledgers. (SQR) Run control parameters allow you to select a ChartField value or a tree with the ChartField values to report. The run control parameters allow you to include vs. exclude system sources.
General Ledger, and then General Reports, and then GL Subsystem Reconciliation, and then Reconciliation by ChartFields
RUN_FIN5005 (RUN_GLRCN_RPTS)
FSX5101
Ledger Translation Errors report (BI Publisher)
Lists the errors from ledger translation. (BI Publisher)
General Ledger, and then Regulatory Ledger Reports, and then Ledger Errors
RUN_FIN5101 (RUN_GLRCN_RPTS)
FSX0007
SpeedTypes Report
Lists all valid SpeedTypes and corresponding information, including the ChartField values that are defined for each SpeedType (BI Publisher report).
Set Up Financials/Supply Chain, and then Common Definitions, and then Design ChartFields, and then Reports, and then Print Speed Type Report
RUN_FIN0007
FSX0011
Valid Department Codes Report
Lists all valid Department values and related information (BI Publisher report).
Set Up Financials/Supply Chain, and then Common Definitions, and then Design ChartFields, and then Reports, and then ChartField Reports, and then Department
RUN_FIN0011
FSX0012
Valid Product Codes Report
Lists all valid Product values and related information (BI Publisher report).
Set Up Financials/Supply Chain, and then Common Definitions, and then Design ChartFields, and then Reports, and then ChartField Reports, and then Product, and then Product
RUN_FIN0012
FSX0013
Valid Project IDs Report
Lists all valid Project ID values and related information (BI Publisher report).
Set Up Financials/Supply Chain, and then Common Definitions, and then Design ChartFields, and then Reports, and then ChartField Reports, and then Project, and then Project ID
RUN_FIN0013
GLX1000
Summary Ledger Definition Report (BI Publisher)
Displays information about summary ledgers, including a description, the detail ledger that it summarizes, record names, and a listing of the ChartFields that are associated with the ledger. (BI Publisher) Transactions that have been journalized will be differentiated between those transactions that have not been journalized. Any ChartField changes that have been made between journalized transaction and the accounting line value will be reported. Information is provided on journals in suspense that originated in the system source.
General Ledger, and then Summary Ledgers, and then Summary Ledger Definition Rpt
RUN_GLC1000
GLX1001
Valid Ledger Codes (BI Publisher)
Displays information about valid ledger codes including associated book codes. (BI Publisher)
General Ledger, and then Ledgers, and then Ledger Codes Report.
RUN_GLC1001
GLX4001
Summary Calendars (BI Publisher)
Displays information about summary calendars. Includes a description as well as a listing of the periods that you have defined for the calendar. (BI Publisher)
Setup Financials/Supply Chain, and then Common Definitions, and then Calendars/Schedules, and then Summary Calendar Report
RUN_GLC4001
GLX4003
Combination Group (BI Publisher)
Displays information on ChartField combination edit groups for a selected SetID. (BI Publisher)
Setup Financials/Supply Chain, and then Common Definitions, and then Design ChartFields, and then Combination Editing, and then Combination Group Report
RUN_GLC4003
GLX4007
Journal Entry Template (BI Publisher)
Displays Journal Entry Templates by the security applied that is available to a user. (BI Publisher). Use this report if you have configured ChartFields to avoid manual changes.
Setup Financials/Supply Chain, and then Common Definitions, and then Journals, and then Entry Template Report, and then Journal Entry Template Report, and then Run, and then Process Scheduler Request, and then and select Journal Entry Template.
RUN_GLC4007
GLX4008
Journal Class Report (BI Publisher)
Displays the journal class name and a description of each for a selected SetID. (BI Publisher)
Set Up Financials/Supply Chain, and then Common Definitions, and then Journals, and then Print Journal Class Report
RUN_GLC4008
GLX5002
Translation Calculation Log
Lists translation calculation details by process instance and translation step. (BI Publisher)
General Ledger, and then Reports, and then Translation Calculation Log
General Ledger, and then Process Multi-Currency, and then Reports, and then Translation Calculation Log
RUN_GLS5002
GLX5003
Revaluation Calculation Log
Lists revaluation calculation details by process instance and revaluation step. (BI Publisher)
General Ledger, and then Reports, and then Revaluation Calculation Log
General Ledger, and then Process Multi-Currency, and then Reports, and then Revaluation Calculation Log
RUN_GLS5003
GLX5004
Translate in Ledger Calculation Log
Lists translation within ledger calculation details by process instance and translate within ledger step. (BI Publisher)
General Ledger, and then Reports, and then Translation in Ledger Calc Log (translation in ledger calculation log)
General Ledger, and then Process Multi-Currency, and then Reports, and then Translation in Ledger Calc Log (translation in ledger calculation log)
RUN_GLS5004
GLX5501
ADB Calculation Report (BI Publisher)
Lists ADB calculation details, including averaged period, date, and time. (BI Publisher)
General Ledger, and then Average Daily Balance, and then ADB Calculation Report
RUN_GLC5501
GLX6001
Allocation Group (BI Publisher)
Lists detail information that is associated with a particular allocation group. (BI Publisher)
Allocations, and then Reports, and then Print Allocation Group Report
RUN_GLC6001
GLX7501
Journal Entry Detail (BI Publisher format)
BI Publisher reports (formerly XMLP) do not require manual changes to support ChartField configuration.
Shows journal entry detail information by business unit, journal ID, date, description, ledger group, source, reversal, foreign currency, rate type, effective date, and effective rate. It also shows line number, account, description, amount, rate type, exchange rate, foreign amount, base amount, and totals for the journal. (BI Publisher)
General Ledger, and then Journals, and then Journal Entry, and then Create/Update Journal Entries, and then Journal Entry Lines Page
Select the Print Journal (XMLP) value in the Process field, and click the Process button. Click the Report Manager button and then click the Journal Entry Print link for the GLX7501 report.
Reporting Tools, Report Manager, and click the Journal Entry Print link to access the GLX7501 report.
RUN_GLC7501
GLX7502
Journal Entry Detail (separate debit and credit) (BI Publisher)
BI Publisher reports do not require manual changes to support ChartField configuration.
Shows journal entry detail information for separate debit credit by business unit, journal ID, date, description, ledger group, source, reversal, foreign currency, rate type, effective date, and effective rate. It also shows line number, account, description, amount, rate type, exchange rate, foreign amount, base amount, and totals for the journal. (BI Publisher)
Note: You must have configured you system for separate debit credit to use this report.
Select the Print Journal (XMLP) value in the Process field, and click the Process button. Click the Report Manager button and then click the Journal Entry Print link for the GLX7502 report.
Reporting Tools, Report Manager, and click the Journal Entry Print link to access the GLX7502 report.
RUN_GLC7502
GLX9001
Amortization Reconciliation Report
Displays information about the amortization reconciliation. Includes the details of the Amortization ID, Business Unit, Amortization Type, Amount, Voucher details, along with a detailed information of all the amortization schedules.
General Ledger, and then Journals, and then Pre-Amortization Journals, and then Create Amortization Recon Rpt
RUN_GLX9001
GLS1001
Summary Ledger Detail
This is a template for designing reports based on user-specific ledger definitions. This is based on the summary ledger (PS_S_LEDGER_SUM), which you can find in the DEMO database. The record definition set consists of the following ChartFields: ACCT, OPERATING_UNIT, DIVISION, PRODUCT_AREA, and PROJ. Contains one statistics code field named STATS. (SQR)
General Ledger, and then Summary Ledgers, and then Summary Ledger Detail Report
RUN_GLS1001
GLS1002
Closing Rules
Displays information about closing set rules. It prints a description of the close set, identifies the name of the account ChartField, and shows the ChartField to which that profit and loss account will be closed. Also shows the option for retaining earnings in the ChartField. (SQR)
General Ledger, and then Close Ledgers, and then Closing Rule Report
RUN_GLS1002
GLS1003
Closing Trial Balance
Summarizes all entries on the ledger by account type. Prints beginning and ending balances for the year, totals for the period, adjustments, and closing entries. (SQR)
General Ledger, and then Close Ledgers, and then Closing Trial Balance Rpt
RUN_GLS1003
GLS1004
Journal Closing Status
Displays the journal line details for journal lines with various closing statuses. (SQR)
General Ledger, and then Close Ledgers, and then Journal Closing Status Report
RUN_GLS1004
GLS1005
Translate Ledger Reconciliation
Reconciles the amounts in the currency translation ledger to the amounts in the primary ledger within a Multibook ledger group. (SQR)
General Ledger, and then Process Multi-Currency, and then Reports, and then Reconcile Translation Ledgers
RUN_GLS1005
GLS1006
Ledger In-Sync
This report searches the currency translation ledger within a multibook ledger to determine whether any data (for a particular year) is violating the required ledger structure. (SQR)
General Ledger, and then Process Multi-Currency, and then Reports, and then Translation Ledger In-Sync
RUN_GLS1006
GLS2000
Elimination Set Definition
Displays all elimination set definitions for financial consolidations. Lists accounts to which differences will post if the set doesn't eliminate and shows the ChartFields (such as ACCOUNT and BUSINESS_UNIT) and the ChartField values that make up the elimination set, as well as a description of those values. (SQR)
General Ledger, and then Consolidate Financial Data, and then Reports, and then Print Elimination Set Report
RUN_GLS2000
GLS2001
Minority Interest Set Definition
Displays the minority interest set definitions for financial consolidations. Lists for each minority interest set a description, tree structure ID, the subsidiary entity, and percent of ownership. Also lists the accounts to which differences will post if the set doesn't eliminate, as well as the ChartField, manner specified, tree name/level, and the values that make up the parent/subsidiary accounts. (SQR)
General Ledger, and then Consolidate Financial Data, and then Reports, and then Minority Interest Sets Rpt
RUN_GLS2001
GLS2002
Consolidation Set Report
Displays the options and controls that tell General Ledger how to process a consolidation. Lists the journal ID mask, source, and relative elimination reversal date for elimination journals, the ChartFields included in the elimination journals, whether all elimination sets that are defined for the consolidation tree will apply, which elimination sets will be used, whether all minority interest sets apply, and which minority interest sets will be used. (SQR)
General Ledger, and then Consolidate Financial Data, and then Reports, and then Consolidation Set Report
RUN_GLS2002
GLS2003
Consolidation Out of Balance Report
Displays the elimination sets and ledger amounts that were processed for a consolidation request. The elimination sets are totaled and any out-of-balance amount is displayed. The out-of-balance amounts are also summarized at the node and tree levels. (SQR)
General Ledger, and then Consolidate Financial Data, and then Reports, and then Print Elimination Report
RUN_GLS2003
GLS2004
Minority Interest Eliminations and Adjustments
Displays the results of minority interest calculations for a consolidation request based on the combination of business units that are present in the consolidation tree. The elimination and adjustment entries are grouped by minority interest set. (SQR)
General Ledger, and then Consolidate Financial Data, and then Reports, and then Minority Interest Elim Rpt
RUN_GLS2004
GLS2005
Audit Elimination Sets
Displays the elimination sets and audit information, including account and business unit. (SQR)
General Ledger, and then Consolidate Financial Data, and then Reports, and then Print Elimination Audit Report
RUN_GLS2005
GLS2006
Equitization Rules
Displays the definition information and purpose for the equitization rule, including component, ChartField, value, and description. (SQR)
General Ledger, and then Consolidate Financial Data, and then Reports, and then Print Equitization Rule Report
RUN_GLS2006
GLS2007
Subsidiary Ownership Sets Report
Shows the ownership, set status, effective date, description, entity ChartField, subsidiary entity, parent, ownership percentage, and controlling equitize. (SQR)
General Ledger, and then Consolidate Financial Data, and then Reports, and then Print Ownership Sets Report
RUN_GLS2007
GLS2008
Equitization Calculation Log
Lists equitization calculation details by process instance. (SQR)
General Ledger, and then Consolidate Financial Data, and then Reports, and then Print Equitization Calc Log
RUN_GLS2008
GLS3000
Open Item Listing
Lists open Items for the accounts specified, including a description of the accounts, the OpenItem key field, and a detailed listing of the journal lines that have an open status up to the as of date. The journal lines are subtotaled by key field value. Journal lines containing OpenItem accounts are matched together based on the OpenItem edit field. (SQR)
General Ledger, and then Open Items, and then Open Item Listing Report
RUN_GLS3000
GLS3001
InterUnit Activity
Displays reconciliation information by business unit, ChartField, primary and balancing values, and variance. (SQR)
General Ledger, and then General Reports, and then Create InterUnit Activity Rpt
RUN_GLS3001
GLS4000
Schedules
Prints a list of the schedules that you have defined for a SetID. The report includes a description of each schedule and the definition of its frequency. (SQR)
Setup Financials/Supply Chain, and then Common Definitions, and then Calendars/Schedules, and then Schedules Report
RUN_GLS4000
GLS4002
Combination Rule
Displays information on a selected ChartField combination edit rule. (SQR)
Setup Financials/Supply Chain, and then Common Definitions, and then Design ChartFields, and then Combination Editing, and then Combination Rule Report
RUN_GLS4002
GLS5000
Translation Definition
Displays the details and rules of each currency translation step. For each translation step, the report shows the description, ledger information, output and journal options, and gain and loss ChartFields. In addition, detailed information is displayed for every translation rule that is used by the translation step. (SQR)
General Ledger, and then Process Multi-Currency, and then Reports, and then Print Translation Step Report
RUN_GLS5000
GLS5001
Revaluation Definition
Displays the details of each currency revaluation step, including revaluation step description, ledger and TimeSpan information, exchange rate type, output and journal options, gain and loss ChartFields, and detailed revaluation ChartField information. (SQR)
General Ledger, and then Process Multi-Currency, and then Reports, and then Print Revaluation Step Report
RUN_GLS5001
GLS5002
Lists translation calculation details by process instance and translation step. (SQR)
General Ledger, and then Process Multi-Currency, and then Reports, and then Print Translation Calc Log
RUN_GLS5002
GLS5003
Lists revaluation calculation details by process instance and revaluation step. (SQR)
General Ledger, and then Process Multi-Currency, and then Reports, and then Print Revaluation Calc Log
RUN_GLS5003
GLS5004
Lists translation within ledger calculation details by process instance and translate within ledger step. (SQR)
RUN_GLS5004
GLS5005
Translate in Ledger Report
Displays the details and rules of each translation step within the ledger calculation log. For each step, the report shows the description, ledger information, output and journal options, and gain and loss ChartFields. (SQR)
General Ledger, and then Process Multi-Currency, and then Reports, and then Translation in Ledger Rprt, and then Translate in Ledger Report
RUN_GLS5005
GLS5500
ADB Definition report (average daily balance definition)
Prints ADB details, including description, purpose, and ChartField information. (SQR)
General Ledger, and then Average Daily Balance, and then ADB Definition Report
RUN_GLS5500
GLS6000
Allocation Step Report
Lists detailed information for allocation steps. (SQR)
Allocations, and then Reports, and then Print Allocation Step Report
RUN_GLS6000
GLS6002
Allocation Calculation Log
Lists the allocation calculations that were performed for a given process step within a specified process instance. Displays the pool, basis, and target amounts. (SQR)
Allocations, and then Reports, and then Print Allocation Calc Logs
RUN_GLS6002
GLS6003
Budget Copy Calculation Log
Lists the Budget Copy Process calculations that were performed for a given process step within a specified process instance. For each process step, the report shows the sequence, business unit, account, department, product, project status, year, period, pool amount, basis amount, basis total, target amount, and offset amount. (SQR)
General Ledger, and then Maintain Standard Budgets, and then Budget Copy Calculation Log
RUN_GLS6003
GLS7001
Standard Journals report
Lists standard journal entries and their status. (SQR)
General Ledger, and then General Reports, and then Print Standard Journal Report
RUN_GLS7001
GLS7002
Ledger Activity report
Lists the beginning and ending ledger balances by ChartField combination and account. Also lists the detailed journal line activity that is posted against the ledger for the accounting periods that are specified. (SQR)
General Ledger, and then General Reports, and then Print Ledger Activities
RUN_GLS7002
GLS7003
Ledger Summary Report
Summarizes journal totals within a ledger by ChartField.
General Ledger, and then General Reports, and then Print ledger Summary Report
RUN_GLS7003
GLS7009
Posted Journal Summary
Provides the ability to report on journals that were posted during a specific run of the Journal Post process. The Journal Post process updates all journals that were posted with the value of the Process Instance. The Process Instance is part of the search criteria that is used by the Posted Journals - Summary report. (SQR)
General Ledger, and then Journals, and then Process Journals, and then Posted Journal Summary Report
RUN_GLS7009
GLS7010
Ledger vs Journal Integrity
Checks for any discrepancy between Ledger and Journal tables within a specified period range. (SQR)
General Ledger, and then General Reports, and then Ledger vs Jrnl Integrity Rpt
RUN_GLS7010
GLS7011
Journal Edit Errors
Provides detailed information about journal edit errors: period, journal ID, date, source, reference number, error type, line, line description, field name, and error message. (SQR)
General Ledger, and then Journals, and then Process Journals, and then Journal Edit Errors Report
RUN_GLS7011
GLS7012
Trial Balance
Combines detail and summary balance information. Shows the ending ledger balances for the specified year and period by ChartField combination. Also displays subtotals by ChartField. Prints a final total for debits and credits. (SQR)
General Ledger, and then General Reports, and then Print Trial Balance
RUN_GLS7012
GLS7015
Journal Suspense Activity
Provides detailed information about suspended journals. (SQR)
General Ledger, and then Journals, and then Suspense Correction, and then Suspended Activity Report
RUN_GLS7015
GLS7016
Ledger Activity with Attributes Report
Lists the journal activity and the associated attributes for one or more specific ChartFields in a ledger for one or more periods, including beginning and ending balances. (SQR)
General Ledger, and then General Reports, and then Ledger Activity Detail Rpt
RUN_GLS7016
GLS7017
General Ledger Activity with Fund and Account Attributes
Generates a FACTS II report for a specific business unit, ledger, fiscal year, period range, adjustment period information, and FACTS tree group. The Program Reporting Category (PRC column heading) can display values for Category A and Category B apportioned funds. You can also indicate that the numeric field can be 23 integers and 3 decimal places long. (SQR)
General Ledger, and then Federal Reports, and then FACTS II Reports, and then Print FACTS II Ledger Attr Rpt
RUN_GLS7017
GLS7500
Ledger File Creation
Reads all entries on the ledger and gives the ending balance for the year and period by account. Output is routed to an ASCII file in the specified format. (SQR)
General Ledger, and then Ledgers, and then Export Ledger Data
RUN_GLS7500
GLS8012
Journal Line/Accounting Entry Reconciliation
Compares journal entry lines with accounting entries. (SQR)
General Ledger, and then General Reports, and then Jrnl to Acctg Entry Recon Rpt (journal to accounting entry reconciliation report)
RUN_GLS8012
GLS8303
FACTS II Accounting Edit Validation
Includes validation edits for account attributes, also includes footnote check to Edit10 when balance is negative, and Edit 8 validation. Shows Program Reporting Category (PRCs) for Category A and B.
General Ledger, Federal Reports, FACTS II Review, Validate FACTS II Data
RUN_GLS8303
GLS8310
FACTS I Validation report
This report is generated when you run the FACTS I Validation process. It describes any outstanding issues for each FACTS I edit that is run for your FACTS I accumulated data. (SQR)
General Ledger, and then Federal Reports, and then FACTS I, and then Generate FACTS I
RUN_CNTL_FACTSI
GLS8311
FACTS I Trial Balance report
This report displays the status of the General Ledger account balances along with the corresponding USSGL account attributes based on each Treasury Symbol. (SQR)
RUN_CNTL_FACTSI
GLS8312
FACTS II Trial Balance
General Ledger, and then Federal Reports, and then FACTS II, and then FACTS II Reports, and then FACTS II Trial Balance
F2_RUN_GLS8312
GLS8400
SF224 Transaction Detail Report
This is a monthly report that includes the detail transactions that make up the totals on the SF224 - Statement of Cash Transactions report.
The detail report supports both regular SF224 and partial SF224 reporting.
General Ledger, and then Federal Reports, and then SF 224/ 1219/1220, and then SF 224 Transaction Report
RUN_GLS8400
GLS8410
SF224 Business Activity Exception Report
Displays transactions that should not be recorded for a particular ALC based on the Business Activity Type code for that ALC. For example, if the ALC is classified with a GWA Business Activity of IPAC Only, then the report reflects any transactions erroneously recorded for CA$HLINK and TDO Payments.
The report reflects data from Accounts Receivable and Accounts Payable. General Ledger journal entry activity is not included in the report.
General Ledger, Federal Reports, SF224/1219/1220, SF224 Bus Activity Exceptions
RUN_GLS8410
GLS8411
ALC GWA Reporting Options Report
Displays Agency Location Codes by SetID and prints the ALC, agency Name, Business Activity Type, and all related GWA Reporter Category Codes by descending effective date and status.
General Ledger, and then Federal Reports, and then CTA / 1219 / 1220, and then Define ALC GWA Rpt Options
RUN_GLS8411
GLS8500
Federal Trial Balance report
This is a summary trial balance report. This report displays a beginning balance, the total amount of debits and credits, and an ending balance. The data is generated for the specified ChartField combination for the fiscal year, accounting periods, and adjustment periods. This report also displays subtotals by ChartField and grand totals by TAS/TAFS levels. Displays the fiscal year grand total. (SQR)
General Ledger, and then Federal Reports, and then Federal Trial Balance
RUN_GLS8500
GLS8501
Federal Transaction Register
This is an online report that displays values at the fund, department, and TAS/TAFS levels for each accounting period along with each ChartField's attributes and attribute values. Displays the Program Reporting Category serving Category A and Category B and also accumulates and displays subtotals by ChartField and grand total. (SQR)
General Ledger, and then Federal Reports, and then Run Federal Txn Report
RUN_GLS8501
GLS9500
Fund Balance Reconciliation
This report is run after you run the Fund Balance Reconciliation process, which compares account activity and trial balance data that is imported from the U.S. Treasury to a federal agency's cash activity. It contains any differences between a federal agency's and the U.S. Treasury's data. (SQR)
General Ledger, and then Federal Reports, and then Fund Balance Reconciliation, and then Generate Reconciliation Report
RUN_FBRECON_RPT
GLSF224P
SF224 is a monthly report to the U.S. Treasury that identifies the dollar amounts of confirmed disbursements and collections by Treasury Symbol, Agency Location Code, and fiscal month. This report is used by the U.S. Treasury to ensure that the agency agrees with the internal U.S. agencies that perform disbursements through the U.S. Treasury. This option enables you to create a flat file of the report to submit electronically through GOALS, and to print a hard copy of the report.
SF224 functionality supports both regular and partial reporting.
General Ledger, and then Federal Reports, and then SF224 / 1219/ 1220, and then Run SF224 Report/Create File
RUN_SF224_SF1220
GLSF1219
Statement of Accountability
This report is used to determine the accountability of disbursing officers for funds that are held outside the Department of Treasury (cash on hand) by U.S. Treasury Regional Finance Centers (RFCs) and other nonmilitary agencies that do not do their own disbursing. This option prints a hard copy version of this report. This report is very similar to the SF1220 report. These two reports are treated as one report when submitted electronically and processed by GOALS using the SF1219/1220 Create option to create the file.
General Ledger, and then Federal Reports, and then SF224/ 1219/ 1220, and then Run SF1219 Report
RUN_SF1219
GLSF224P
Statement of Transactions According to Appropriations, Funds, and Receipt Accounts report
Provides the U.S. Treasury with a monthly statement of payments and collections that are performed by agencies that do their own disbursing. This option prints a hard-copy version of this report. This report is very similar to the SF1219 report. These two reports are treated as one report when submitted electronically and processed by GOALS using the SF1219/1220 Create option to create the file.
General Ledger, and then Federal Reports, and then SF224/ 1219/ 1220, and then Run SF1220 Report
RUN_SF224_SF1220
