General Ledger WorkCenter - Queries Page (Fluid)
Use the General Ledger WorkCenter - Queries page to access Query Manager, and frequently-used public queries and private queries, without leaving your WorkCenter.
Navigation
Select the General Ledger WorkCenter tile and expand the Queries pagelet.
This example illustrates the fields and controls on the General Ledger WorkCenter - Queries Pagelet (Fluid).
General Ledger WorkCenter - Queries (Fluid)
The Queries pagelet includes links to Query Manager, public queries, and private queries. The system administrator can determine if an end user can add public or private queries, and you can personalize your queries accordingly. When a link is selected, the results are displayed in the transaction pane of the WorkCenter (right side) or in a new window. As in Query Manager, the query results that you generate from within your WorkCenter can be downloaded and saved to Microsoft Excel.
